Posted (edited)
Hi,
I have a newly installed Kodak OG 5.48 inverter and 4x12V100AH Vision 6FM100Z-X batteries in series.
Firmware
Main CPU version: 47.00
I have been struggling to charge the batteries past the default float voltage.
The default AGM battery type settings (float = 54, Bulk=56.4V) have not been able to give a full charge and the battery voltage quickly drops during load-shedding to 50V and then slowly starts tapering. I expect that this will happen from the float voltage without the big initial drop.
I have now upped the float to 55.2 and the charging current to 30A (initial 10A). Am I missing the obvious?
Any advice would be appreciated.
Edited by NewbyKodak
  • NewbyKodak changed the title to Kodak OG 5.48 inverter undercharging 4x12V100AH
Posted (edited)
11 hours ago, NewbyKodak said:
Firmware
Not in my collection, unfortunately.
That could well be the premature float bug.
100 Ah is a bit light for a 5 kW inverter. You should not use too much power during load shedding.
The sudden drop is expected, as the battery goes from being charged to being discharged, but a full battery (with a light load) should drop to some 51.x volts. 50 V (12.5 V per 12 V module) indicates a middling state of charge.
It would be better to set the timed absorb ("Bulk charging time") setting to about 60-90 minutes instead. Otherwise, you risk eventually over-charging your battery. This should be setting 32 on your inverter, or a suitably named option on your monitoring software (if any).
Quote
Usually, charging current in amps should be about 15% of the capacity of the battery (in Ah). So that would be 15 A. I would round that up to 20 A.
Thanks Coulomb,
That is very helpful. I don't seem to have a "Bulk charging time" setting.
Looks like it is also possible to accomplish the same using the equalization function.
Would the following work?
Battery Equalization
Equalization : Enable
Time    :  90
Period  : 5 days
Voltage : 56.4V
Timeout :  120 min
Regards,
That's odd.
Period  : 5 days
Yes, that would work, but I'd change the period to 1 day, so you'll get the benefit every day, not every fifth day.
Thanks,
I update my settings and set the period to 1 day.
There is no setting for the start time. I waited a day and eventually manually kicked off the equalization. Does the count down to the next run start from the last equalization run?
And lastly, the voltage dropped back down to the float voltage within about 15 minutes after 90min @ 56.4V, is this considered normal?
Sorry, no idea.
Yes. It's immediately in float mode after the end of absorption, or indeed after timed absorb if you have that feature. But it would usually have a "normal" absorb stage before that, so equalising (different to timed absorb) is in addition to the "normal" absorb stage.
