cyber7 Posted May 27, 2022 Share Posted May 27, 2022 (edited) As per the subject: I would like to know if anyone started a project of collecting local data from a SunSynk WiFi Dongle? I am sick of server-outages and lost data and am thinking of either hi-jacking the traffic (on my router) to SunSynk's cloud storage or cracking open the dongle and re-programming the NCU chip... My Question: Has anyone thought or started something like this? regards Aubrey (aka cyber7) ps - as an afterthought, this could even work for that "other" dongle we all got with our systems for free Edited May 27, 2022 by cyber7 make the circle bigger Quote Link to comment Share on other sites More sharing options...
cyber7 Posted May 27, 2022 Author Share Posted May 27, 2022 ps - thought about it and it will be easier just plugging a "serial cable" into the inverter... system32 1 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted May 27, 2022 Share Posted May 27, 2022 When you say the "Sunsynk dongle", are you talking about the new Sunsynk dongle or the older Solarman dongle that plusg into the Sunsynk inverters? I don't know of any projects using the new Sunsynk dongle's as yet There are a number of projects using the Solarman Dongle for connection via Wifi to Home Assistant. https://github.com/StephanJoubert/home_assistant_solarman Otherwise you can bypass the dongle altogether and connect using the RS485 port on the inverter with a USB/RS485 converter to you Home Assistant box. https://github.com/kellerza/sunsynk or you can use the Node Red Flows created by @Bloubul7 cyber7 1 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted May 27, 2022 Share Posted May 27, 2022 There are loads of threads on this forum with more information on this topic. cyber7 1 Quote Link to comment Share on other sites More sharing options...
cyber7 Posted May 30, 2022 Author Share Posted May 30, 2022 Jup, but it is going to take just one small upload to overwrite the firmware on that nodemcu Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted May 30, 2022 Share Posted May 30, 2022 @cyber7Which wifi dongle are you talking about, the Sunsynk App or the Solarman App one? Would be useful if someone could work out how to query readings & write inverter setting changes directly to the Sunsynk dongle. Quote Link to comment Share on other sites More sharing options...
valienté Posted May 31, 2022 Share Posted May 31, 2022 (edited) Indeed there are loads of information regarding the Solarman Logger - However, info on the new Sunsynk Data Logger seems impossible to find. If @cyber7 was talking about the newer logger, then please confirm and we can utilize this thread going forward to explore the possibility of reading and writing data to the Inverter via the Sunsynk Data Logger. This is what the Sunsynk Data Logger looks like: Edited May 31, 2022 by valienté Quote Link to comment Share on other sites More sharing options...
cyber7 Posted June 1, 2022 Author Share Posted June 1, 2022 14 hours ago, valienté said: Indeed there are loads of information regarding the Solarman Logger - However, info on the new Sunsynk Data Logger seems impossible to find. If @cyber7 was talking about the newer logger, then please confirm and we can utilize this thread going forward to explore the possibility of reading and writing data to the Inverter via the Sunsynk Data Logger. This is what the Sunsynk Data Logger looks like: Confirmed valienté 1 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted June 1, 2022 Share Posted June 1, 2022 Going to follow this thread with interest Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted June 1, 2022 Share Posted June 1, 2022 Is an ESP32 MCU, would be cool to reflash with ESPhome and pull all the data from the inverter that way. cyber7 and valienté 2 Quote Link to comment Share on other sites More sharing options...
cyber7 Posted June 9, 2022 Author Share Posted June 9, 2022 If you look at the board and the data-sheet - URL TO PDF - you will see only a few pins are being used... Should be able to break into the board quite easily by running wireshark and looking at the data coming out of the network... valienté 1 Quote Link to comment Share on other sites More sharing options...
valienté Posted June 20, 2022 Share Posted June 20, 2022 On 2022/06/09 at 11:47 AM, cyber7 said: If you look at the board and the data-sheet - URL TO PDF - you will see only a few pins are being used... Should be able to break into the board quite easily by running wireshark and looking at the data coming out of the network... I briefly used Wireshark back in the day, but that only gave info on the Device it was running on... How would one get the info from the Logger running on the network? Quote Link to comment Share on other sites More sharing options...
frankie Posted July 16, 2022 Share Posted July 16, 2022 To confirm do you want to pull the firmware from the nodemcu, or just utilise their API? It might be easier to just write some HA integration which directly talks to the SunSynk cloud APIs to pull the data. For the SynSynk API see below. Login and obtain bearer token https://pv.inteless.com/oauth/token POST /oauth/token HTTP/2 Host: pv.inteless.com Content-Length: 103 Accept: application/json Content-Type: application/json;charset=UTF-8 Sec-Ch-Ua-Mobile: ?0 User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.74 Safari/537.36 Origin: https://sunsynk.net Referer: https://sunsynk.net/ Accept-Encoding: gzip, deflate Accept-Language: en-GB,en-US;q=0.9,en;q=0.8 {"username":"XXXXXX","password":"XXXXXX","grant_type":"password","client_id":"csp-web"} Some endpoints api/v1/plants api/v1/plant/energy/XXXX/flow api/v1/inverters api/v1/inverter/XXXX/realtime/output api/v1/inverter/XXXX/realtime/input api/v1/inverter/battery/XXXXX/realtime Then you can utilise the bearer token to extract data from the APIs. Use the below to obtain your PlantID. Change the XXXXX with your bearer token. GET /api/v1/plants?page=1&limit=10&name=&status= HTTP/2 Host: pv.inteless.com Accept: application/json Authorization: Bearer XXXXXXX User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.74 Safari/537.36 Origin: https://sunsynk.net Referer: https://sunsynk.net/ Accept-Encoding: gzip, deflate Accept-Language: en-GB,en-US;q=0.9,en;q=0.8 The below will give you general FLOW data for a given date e.g. battPower, load etc. Change the XXXXX with your bearer token and your plantID. GET /api/v1/plant/energy/XXXXX/flow?date=2022-07-16 HTTP/2 Host: pv.inteless.com Accept: application/json Authorization: Bearer XXXXXX Sec-Ch-Ua-Mobile: ?0 User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.74 Safari/537.36 Origin: https://sunsynk.net Referer: https://sunsynk.net/ Accept-Encoding: gzip, deflate Accept-Language: en-GB,en-US;q=0.9,en;q=0.8 If you want to directly query raw output from your inverter, then you have to obtain the InverterID first. Change XXXX with your bearer token. GET /api/v1/inverters?page=1&limit=10&total=0&status=-1&sn=&plantId=&type=-2&softVer=&hmiVer=&agentCompanyId=-1&gsn= HTTP/2 Host: pv.inteless.com Accept: application/json Authorization: Bearer XXXXXX User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.74 Safari/537.36 Origin: https://sunsynk.net Referer: https://sunsynk.net/ Accept-Encoding: gzip, deflate Accept-Language: en-GB,en-US;q=0.9,en;q=0.8 Then you can plugin it at several spots in the API. Change XXXXX with your inverter ID and your bearer token. GET /api/v1/inverter/XXXXXX/realtime/output HTTP/2 Host: pv.inteless.com Accept: application/json Authorization: Bearer XXXX User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/99.0.4844.74 Safari/537.36 Origin: https://sunsynk.net Referer: https://sunsynk.net/ Accept-Encoding: gzip, deflate Accept-Language: en-GB,en-US;q=0.9,en;q=0.8 Welcome to msg me if you want to know more. If you do ever do some integration in HACS please share. I've not gone so far as to actually write something, but should be easy. 949BFN and Sc00bs 2 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted August 16, 2022 Share Posted August 16, 2022 (edited) Good suggestion @frankie that would be pretty cool @kellerza Did a similar Integration for HA for the Solarman Dongle, not sure how similar they are, is way above my paygrade lol https://github.com/kellerza/sunsynk Oops, sry, the KellerZa integration is via the RS485 port. There is one using the Solarman dongle, just need to find it Edited August 16, 2022 by Sc00bs Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted August 16, 2022 Share Posted August 16, 2022 The Solarman integration https://github.com/StephanJoubert/home_assistant_solarman Quote Link to comment Share on other sites More sharing options...
system32 Posted September 16, 2022 Share Posted September 16, 2022 (edited) SolarMan WiFi Dongle Hacking.... https://csirt.divd.nl/cases/DIVD-2022-00009/ To be fair, the issue was the publishing of super admin passwords for the backend on github. Edited September 16, 2022 by system32 Sc00bs 1 Quote Link to comment Share on other sites More sharing options...
Sc00bs Posted September 16, 2022 Share Posted September 16, 2022 Interesting Quote Link to comment Share on other sites More sharing options...
TheRoDent Posted September 18, 2022 Share Posted September 18, 2022 (edited) So the "Sunsynk Data Logger" is basically this product from e-linter ? inteless.com, minus the RJ45/Ethernet http://e-linter.com/smart-energy/goldfinch https://doc.inteless.com/page/p/goldfinch/manual/db9/index.html According to the documentation, the comms between the inverter and the Data Logger is RS-232. I'm not entirely sure what protocol the RS-232 port on the Sunsynk inverter presents, but I'm going to guess it's probably ModBUS over RS-232. If someone can find a binary blob for the firmware of the dongle, I can probably take a stab at reverse-engineering it. Solarassistant.io seems to be capable of supporting it over RS-232 directly. Edit: Seems like this document in this thread confirms that it's modbus over RS-232 at 9600bps. The cloud API stuff seems like a pretty closed ecosystem, other than the interesting API information that @frankie has posted earlier. At worst, using those API's might be the best way to get the data logger into Home-Assistant, but I'd prefer something that doesn't depend on inteless's cloud API. @frankie did you sniff the application traffic on a phone to get a hold of the API calls ? If so, nicely done. The image that @Sc00bs posted suggest that on the top right hand there are pads for T/R/G which I would assume is the ESP TTL Transmit/Receive/Ground, so in theory those could be used to flash it. The device's web interface itself doesn't offer more than upgrading software or changing WiFi SSID. There doesn't appear to be any ports open other than http(80). I might just try and give it an ESPHOME image and see if it's willing to upgrade to a new custom firmware. Edited September 18, 2022 by TheRoDent Quote Link to comment Share on other sites More sharing options...
TheRoDent Posted September 18, 2022 Share Posted September 18, 2022 (edited) 1 hour ago, TheRoDent said: So the "Sunsynk Data Logger" is basically this product from e-linter ? inteless.com, minus the RJ45/Ethernet http://e-linter.com/smart-energy/goldfinch https://doc.inteless.com/page/p/goldfinch/manual/db9/index.html According to the documentation, the comms between the inverter and the Data Logger is RS-232. I'm not entirely sure what protocol the RS-232 port on the Sunsynk inverter presents, but I'm going to guess it's probably ModBUS over RS-232. If someone can find a binary blob for the firmware of the dongle, I can probably take a stab at reverse-engineering it. Solarassistant.io seems to be capable of supporting it over RS-232 directly. Edit: Seems like this document in this thread confirms that it's modbus over RS-232 at 9600bps. The cloud API stuff seems like a pretty closed ecosystem, other than the interesting API information that @frankie has posted earlier. At worst, using those API's might be the best way to get the data logger into Home-Assistant, but I'd prefer something that doesn't depend on inteless's cloud API. @frankie did you sniff the application traffic on a phone to get a hold of the API calls ? If so, nicely done. The image that @Sc00bs posted suggest that on the top right hand there are pads for T/R/G which I would assume is the ESP TTL Transmit/Receive/Ground, so in theory those could be used to flash it. The device's web interface itself doesn't offer more than upgrading software or changing WiFi SSID. There doesn't appear to be any ports open other than http(80). I might just try and give it an ESPHOME image and see if it's willing to upgrade to a new custom firmware. Whilst it would be great to get this going, as a home-brew, I just took the plunge and installed @SolarAssistant on a Raspberry Pi, with a USB-RS232 adapter. Simplest, easiest integration I've ever done, and solarassistant.io is superbly slick. Well done. I now have a useless Sunsynk Data Logger, which I shall attempt to brick at my own leisure using ESPHome. Edited September 18, 2022 by TheRoDent MdF 1 Quote Link to comment Share on other sites More sharing options...
mzezman Posted September 19, 2022 Share Posted September 19, 2022 18 hours ago, TheRoDent said: Whilst it would be great to get this going, as a home-brew, I just took the plunge and installed @SolarAssistant on a Raspberry Pi, with a USB-RS232 adapter. Simplest, easiest integration I've ever done, and solarassistant.io is superbly slick. Well done. I now have a useless Sunsynk Data Logger, which I shall attempt to brick at my own leisure using ESPHome. wouldnt you need to keep the dongle for firmware updates? Solar Assistant currently doesn't do that system32 1 Quote Link to comment Share on other sites More sharing options...
RoganDawes Posted October 3, 2022 Share Posted October 3, 2022 (edited) I pulled the firmware off my dongle, which looks slightly different to the pictures that were posted earlier. My ESP32 is a RISC-V based C3. I'm happy to share some of the partitions, but a couple of them have my home WIFI details embedded in them. I had a go at reverse engineering them with Ghidra, but ran into the problem of specifying the memory map, which I am not quite sure how to do. But yeah, I'd be quite keen to get an ESPHome-based firmware running on the Sunsynk dongle. While kellerza has done a sterling job with the sunsynk plugin, I'm trying to move away from the MQTT server towards native ESPHome protocol. If I need to do any firmware updates, I can always flash the original firmware back, since I took a copy. Edited October 3, 2022 by RoganDawes Robbo 1 Quote Link to comment Share on other sites More sharing options...
RoganDawes Posted October 3, 2022 Share Posted October 3, 2022 This is my dongle. iiznh 1 Quote Link to comment Share on other sites More sharing options...
Madek Posted October 4, 2022 Share Posted October 4, 2022 On 2022/05/31 at 5:11 PM, valienté said: Indeed there are loads of information regarding the Solarman Logger - However, info on the new Sunsynk Data Logger seems impossible to find. If @cyber7 was talking about the newer logger, then please confirm and we can utilize this thread going forward to explore the possibility of reading and writing data to the Inverter via the Sunsynk Data Logger. This is what the Sunsynk Data Logger looks like: Got a surprise the other day. Previously sunsylk issued a magneto data logger with their inverters (looks like it) . We could not understand why we can not find the client on the sunsylk app. Then saw they gave us a magneto data logger that can only work on solarman. I also ordered an add data logger 6mnths ago. When we wanted to replace the magneto data logger that was issued 2yrs ago with the installation we found out they gave us again a magneto data logger. Still gotto contact the supplier. I want to know how could they sell a magneto data logger to us if the order stupilated a sunsylk dongle. Anyone else with the same problem? Quote Link to comment Share on other sites More sharing options...
you1 Posted October 6, 2022 Share Posted October 6, 2022 I can provide a wireshark capture of the logger traffic, if anyone is interested to try and decipher it. At the moment I'm pulling the modbus data directly from the inverter, so I'm not really motivated to use whatever the logger is pushing out. RoganDawes 1 Quote Link to comment Share on other sites More sharing options...
RoganDawes Posted October 6, 2022 Share Posted October 6, 2022 1 hour ago, you1 said: I can provide a wireshark capture of the logger traffic, if anyone is interested to try and decipher it. At the moment I'm pulling the modbus data directly from the inverter, so I'm not really motivated to use whatever the logger is pushing out. I’m running OpenWrt on my router, so have wireshark captures already. I think what I need to do next is capture the serial traffic and the tcp traffic at the same time, to see what the dongle is adding to the connection, or if it is doing any protocol translation. Quote Link to comment Share on other sites More sharing options...
