Posted June 19, 20223 yr Hi i would like to find out where i can find a replacement communications board for the above mentioned inverter. The supplier obviously doesn’t supply or repair them only swop it out if within 6 months.
June 19, 20223 yr 1 hour ago, RiPMonsteR said: The supplier obviously doesn’t supply or repair them Yes. This is clearly a clone, so you won't get any support. There have been reports of replacement comms boards being found; search the forum. However, I don't know if the 24 V models have the same comms board as the 5 kVA 48 V models.
June 19, 20223 yr Author 4 hours ago, Coulomb said: Yes. This is clearly a clone, so you won't get any support. There have been reports of replacement comms boards being found; search the forum. However, I don't know if the 24 V models have the same comms board as the 5 kVA 48 V models. Thanks i will search however the Axpert 3kva models are identical to the T
