minesh Posted June 20, 2022 Share Posted June 20, 2022 (edited) Inverter with wifi dongle, all working fine. Selling this to buy a 8kw inverter with 2 mppt. Looking for R8000.00 General Model: SPF 5000TL HVM-P. Battery voltage: 48VDC. Inverter Output Waveform: Pure Sine-Wave. Rated Power: 5000VA/5000W. Parallel Capability: Yes, 6 units. AC Voltage Regulation (Battery Mode): 230VAC ± 5% @ 50/60Hz. Surge Power: 10000VA. Efficiency (Peak): 93%. Transfer Time: 10 ms (For Personal Computers); 20 ms (For Home Appliances). Solar Charger Maximum PV Array Power: 4500W. MPPT Range @ Operating Voltage: 60VDC ~115VDC. Standby Power Consumption: 2W. Maximum PV Array Open Circuit Voltage: 145VDC. Maximum Efficiency: 97%. Maximum Solar Charge Current: 80A. AC Charger Charge Current: 60A. AC Input Voltage: 230 VAC. Selectable Voltage Range: 170-280 VAC (For Personal Computers); 90-280 VAC (For Home Appliances). Frequency Range: 50Hz/60Hz (Auto sensing). Physical Dimension (D/W/H) in mm: 130*350*455. Net Weight (kgs): 14.5 Edited June 20, 2022 by minesh added more specs Quote Link to comment Share on other sites More sharing options...
