Posted July 9, 20222 yr Hi, i have just installed a 12kw 3ph deye inverter with 3 x Hubble 5,5 kw batteries, the system is totally offgrid with no backup , as there was no cans cable i set it on V,and it works ok, i have received the cable and did the setting changes but i get a bms shutdown error after the reset, i turned off the bms alarm and it worked fine for about 8hrs then shut the system down. i put it back on voltage and its been working in that mode for a couple of days with no problem but i want it to operate correctly on lithium and get the optimum performance from the batteries, any tips will be appreciated because its driving me nuts
July 22, 20222 yr Hi Jerry, I have did the exact same installation and the same issue. Will be able to talk you through it if you are at the inverter. I, accidentally noted in the Sunynk 3 Phase manual page 66, that the 3P inverters are not designed for off grid. There is a way around it though, ill just go double check the exact settings and send it to you.
