Posted June 4, 20178 yr Hi All, I have a 48V 5MKS that sometimes gets overdrawn into the beep zone. Was thinking of paralleling another unit and see the 5ks on special for R5670. Besides the missing MPPT - any reason not to parallel an MKS and a KS unit? thanks
June 4, 20178 yr The firmware has to be the same version number exactly on all paralleled machines, and I don't think that this is possible wirh an MPPT and a PWM model. So: probably not.
June 5, 20178 yr 20 hours ago, Coulomb said: The firmware has to be the same version number exactly on all paralleled machines, and I don't think that this is possible wirh an MPPT and a PWM model. So: probably not. I would concur. the solar charger, whether MPPT or PWM is connected directly to the batteries via the DC bus. Chances are, they have some different calculations on the voltages and ampere so if you do manage to get this to work, the one will probably under charge the whole time, or not charge at all. OR, worst case, blow something up.
June 8, 20178 yr Author Apologies for the delay in reply I have been travelling. Many thanks for the responses - insights are much appreciated.
