Bowsie Posted July 25, 2017 Share Posted July 25, 2017 Hi, I have a problem with a Axpert MKS 48V. Program 29 is not letting me adjust the battery cut off and has a little spanner next to it. I'm guessing it is another setting that is blocking it. Any Ideas? Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted July 25, 2017 Share Posted July 25, 2017 HI Bowsie The little spanner shows you are in the menu setup mode. If you press enter when program 29 is highlighted the 42.0 V will start to flash and you can then use the up and down buttons to change the setting between 40 and 48V in 0.1V increments. Press Enter again to select the value. Then press Esc to leave the settings menu cycle. Quote Link to comment Share on other sites More sharing options...
Bowsie Posted July 25, 2017 Author Share Posted July 25, 2017 Hi Chris, Hope you well. Ah, never noticed the spanner before. I have adjusted all the other programs, but 29 won't let me move up or down. Will have to have another go at it. Quote Link to comment Share on other sites More sharing options...
