PaulF007 Posted August 19, 2017 Share Posted August 19, 2017 Morning Guys Starting with emoncms , if you follow the official page can seem to be a bit daunting. So I decided to build a "Portable" version of emoncms. It runs from a little program called USB Webserver and all the settings is taken care of. All you need to do is run the installer and make sure to install the program in your C drive as all the settings is setup in that way and register a new user. Also you will need to open the firewall port on your PC but windows firewall will popup some prompts with the first run. So far I could not find any problems. But please post I you pick something up. Here is the link to the file: Best regards Paul Chris Hobson, GVC, pilotfish and 1 other 1 3 Quote Link to comment Share on other sites More sharing options...
Egon Posted May 3, 2018 Share Posted May 3, 2018 Hi Paul Do you perhaps still have this file available? I would really like to give it a try, but the Dropbox link does not exist anymore. Alternatively, do you have any advice on how to set up the portable server myself? Regards Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted May 5, 2018 Share Posted May 5, 2018 Why did you install it on Windows? Quote Link to comment Share on other sites More sharing options...
