Hey everyone
I want to split my stove and geyser and some other plugs so they are not on the inverter
Does one get a EL that can take two inputs, one from Eskom and then one from my Inverter? I was hoping to replace the one I have now as the dub board is full with an EL that can take two red wires in.
I assume wit the EL one can use a single neutral bar and either circuit will trip EL should there be an issue?
my other issue is that I have thick wires to take to change over switch, and I can not fit two into the CB in order to split it to change over switch and the other one to the circuit that will not be in the backup solution. What can one use ?
