Hi all, new here and have seen a few mentions of this "German" inverter but not the specific query.
Recently moved into house with 2x Schubart inverters (Model Name: PS 6800VA), 4x 4kwp LiFe batteries and 24x 340W panels.
Previous owner misplaced the manual and I believe the monitoring software that came with the inverter. Does anyone know where I can find these online or otherwise?
Additionally, the previous owner appears to not have connected the inverters to the grid and instead used a switch to manually switch between solar/batteries and Eskom. I know, I know... I've seen a lot mentioned about off-grid inverters, would this model be able to use Eskom in addition to the solar/battery inputs?
Any help or advice much appreciated.
https://www.solarmansa.co.za/schubart/
On this page you can get the specs and a quote for this inverter. May be you can get more details from them.
It seems like the display is just like the 145V MPPT Axpert/Mecer models. The manual for the Axpert might match the settings on your inverters and a good start.
  • 5 weeks later...
  • 3 months later...
On 2023/07/23 at 2:54 PM, tlello said:
Hi there
@Legendry
have you been able to get the wifi dongle? I am looking for one for my invertor. Tx
Hi tlello,
I have not bought one yet, but from what I could establish the MUST Dongle for the PV1800 models will work. You can get them from Solarwarehouse SA [https://solarwarehousesa.com/products/must-esener-3kva-wifi-dongle-for-3kwh-5-2kwh-inverters?_pos=1&_sid=cc9b2e8e3&_ss=r] for about R900.
  • 10 months later...
