Hi all,
Does anyone have any experience and is it possible to connect a small 2.5kW generator via a changeover switch to force charge the batteries in a PV installation, simply replacing the mains supply and charging when the PV array is not generating?
PV array is set up in a normal configuration.
To me its seems viable?
Will also enable me to maintain the house in the event of a power cut.
Thanks in advance for any assistance.
Regards,
Hi, depending on inverter it might have a connection for generator already.  No expert on this at all. But know there is some inverters that does not play along. On Sunsynk I know you can limit the amount of power it pulls from generator input( Guess Dye will be same).
Regards
