Posted January 7, 20232 yr Item Wanted: G-ST18i3 male and female connectors (1 each) (for Victron 24V Multiplus Compact) Packaging Essential: No Desired Age: Any, as long as it is in good condition. Need either the rewirable connectors or the connectors on cable.* Location: Fourways, JHB Willing to accept a shipped item: Yes, I will arrange shipping with TCG Ballpark/Budget Amount: Up to R120 for each. *I ordered this from RS Electronics but while the adapters fit physically the metal contact pins inside were inverted. I want to try asking on here first as RS Electronics has a minimum order of 5 pieces for each connector (for the ones I want) - 92.932.3053.1 | Wieland, GST18i3 Male 3 Pole Mini Connector, Cable Mount, with Strain Relief, Rated At 20A, 250 V | RS (rs-online.com) - 92.931.3053.1 | Wieland, GST18i3 Female 3 Pole Mini Connector, Cable Mount, with Strain Relief, Rated At 20A, 250 V | RS (rs-online.com) Edited January 7, 20232 yr by TRINITRON updated with product links
March 14, 20232 yr You can get these from RS-Online for around R90. https://za.rs-online.com/web/c/connectors/power-connectors/lighting-connectors/?searchTerm=gst18i3
