Posted January 10, 20232 yr Hi, I have an Axpert king rack 5k invertor connected to solar pannels, charging 4 Pylontech us2000c batteries. I have purchased a small wind turbine, generating up to 400w on 12v AC. Can I connect it directly to the AC input on the Axpert invertor? Where my backup Honda generator is usually connected? This is an Off-Grid setup Thanks
January 12, 20232 yr I answered this in a PM. Basically, 12 VAC can't be used at the 230 VAC input to the inverter. OP has to figure out what the output of the supplied wind charge controller is designed for,
