Gentleman
I am assuming that the current rating should be the same as the current rating of at least the inverter ac output. Am I correct?
Many thanks
I too am curious what is used for the bond cable size, to me it is a reference join and should be same size cable as the other conductors but I see some people use 5A relays and 2.5mm conductors.
To add I have also done that way before but since changed to using same size conductor.
Then the relays become large and difficult to source. Relays above 25A are scarce and typically only available for 4 pole etc which is a massive waste.
5A is more than enough as there is no load between neutral and earth.
