Posted January 12, 20232 yr Hi all, what do you think of this entry setup to run a medium household during loadshedding - can upgrade letter to Solar and one more battery? Mecer Axpert MAX 5.6KW (SOL-I-AX-5M4), 6KW MPPT inverter with Dyness 4.8KW battery (SOL-I-AX-5M4)
January 12, 20232 yr We have no idea what you mean by medium household. Have you calculated your loads? Typically you want to figure out your peak load, then figure out what your essential load will be, then work out what combo of inverter and battery will support that with your given budget
