Posted January 16, 20232 yr Hi All, Newbie here So I have an Axpert 5kva inverter connected to a 5kva Fivestar Lithium battery. Unfortunately last night due to load shedding it seems that they system has run flat! I fired up the generator this morning and plugged the inverter into it. It however will not turn on. Will I need to get a charger to charge the lithium up first to get it to turn on again?
January 16, 20232 yr some axperts are very fussy on generator input. I would try to get the battery up first
January 16, 20232 yr Author Hi, So I was able to get the battery charged enough to get the inverter to come online again. I have been watching the Soc on the battery and it seems to have stopped at 60.57%. Would anyone be able to assist with some idea as to how to correct this? Im not sure if perhaps the Inverter settings might have changed from being offline? Again, really new to this and am really confused as to what the optimal settings should be. Would really appreciate your expert advice!
