ghatikar Posted November 6, 2017 Share Posted November 6, 2017 PeepsLatest News from Tapeta street Home Project A more mechanically talented guy from my office helped me install ( actually he did the install I just watched � ) over two days this weekend the first wind turbineI was also in parallel installing the BYD LIfepo4 batteries – 10 KWh 48 VSee video for turbine in operation - https://www.youtube.com/watch?v=mI84Xa_9LA4 It is a cheap Chinese make horizontal axis wind Turbine rated 200 Watt /24 V DC connected to the drivers /maids room through an off grid setup of 3 KWH . It is also augmented by 800 watt of Solar PV Cut in Speed 2 m/s - rated 11 m/s - Installation location - 9.078 7.482 , 492 m+ 14 metersweather history - https://www.wunderground.com/personal-weather-station/dashboard?ID=IABUJA3#history/tgraphs/s20171106/e20171106/mdailyI have also on order a Vertical Axis 300 Watt wind turbine to compare. Will be installed next year Now I have Four different RE models running in the same house 1. Pure Offgrid – 24 V DC Solar PV+ Wind – AGM batteries – 3KWH. 0.8 Kwp Solar2. DC coupled Hybrid – Grid + Solar PV + Diesel, 48 V Flooded lead acid , 20 KWh( 10 KVA peak) – 2.5 Kwp solar3. AC coupled Grid Tie ( normally running in islanding mode daytime) - Solar PV +Diesel Hybrid + Micro Grid inverter ,Lithium batteries – 10 KWh ( 5 KW peak) , 48 V DC – 3 Kwp Solar4. Solar thermal – 120 Litters EV tube water heater with PV Solar assisted 1.5 Kwp heater and 100 watt water boost pressure pump Quote Link to comment Share on other sites More sharing options...
