Mako Posted November 20, 2017 Share Posted November 20, 2017 Asking for a friend in Langebaan. The plans for a new house have been drawn. Two roof pitches facing NW for panels. The question is around future proofing in terms of the electrical wiring. What should be done to ease a later solar install at the distribution board? Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted November 20, 2017 Share Posted November 20, 2017 Two separate DBs with more space than you think you need. Conduit for PV. ..... and for feks sake my pet gripe lay the conduit for plugs etc and then plaster over it rather than plaster and then cut grooves in the plaster for the conduit. ___, Sidewinder and Mako 3 Quote Link to comment Share on other sites More sharing options...
___ Posted November 20, 2017 Share Posted November 20, 2017 5 hours ago, Chris Hobson said: Two separate DBs with more space than you think you need. Agreed. The main DB holds the main switch, earth leakage, and breakers for the geyser and stove (if applicable). Then a sub-DB that has the rest of the breakers for plugs and lights, with enough space for additional devices (you're going to need another earth leakage downstream later, quite likely). When the inverter comes later, it goes between the two DBs. Quote Link to comment Share on other sites More sharing options...
Chris Hobson Posted November 21, 2017 Share Posted November 21, 2017 Perhaps look at East-West facing roofs rather than north facing. East -West is better for self consumption (longer solar day) and yields only 10% less than a North facing roof. Quote Link to comment Share on other sites More sharing options...
Mako Posted November 21, 2017 Author Share Posted November 21, 2017 Thanks for the input so far Chris and Plonkster. East West isn't going to happen mainly because the plans are done / submitted, also the house overlooks the lagoon and orientation on the sloping plot is fixed. Mrs. Friend has decided ;-) The way it's laid out now will also provide a walkway along the base of each pitch for easy cleaning of the panels. Quote Link to comment Share on other sites More sharing options...
