deonholt Posted February 28, 2023 Share Posted February 28, 2023 URGENT, PLEASE Hi and thanks for your help. We have been without power since last night 23:00. The daytime with the solar helped to charge the batteries and run the household. I have a small 3kVA generator with AVR. I had a "Fivestar" 3kVA inverter before this one and used the generator to charge the batteries through a changeover switch I installed. BUT, now my Sacolar inverter does not accept the generator as Mains supply. My batteries have 2V left and we will definitely not make ot through the night. We have already heard of criminal activities last night. Please advise me on what I need to do/set the inverter at to accept the supply of the inverter. the frequency is stable around 50Hz and the voltage around ±220. Please, please. Thanks. Quote Link to comment Share on other sites More sharing options...
PsyWulf Posted February 28, 2023 Share Posted February 28, 2023 "Stable" is relative,you might need to ramp your Mains charge amps down,and use something to spin up the generator load to get it stable at load,then change over and start increase your charge rate slowly Coulomb 1 Quote Link to comment Share on other sites More sharing options...
deonholt Posted February 28, 2023 Author Share Posted February 28, 2023 8 minutes ago, PsyWulf said: "Stable" is relative,you might need to ramp your Mains charge amps down,and use something to spin up the generator load to get it stable at load,then change over and start increase your charge rate slowly Thanks. I managed to find a setting where I could change the input to "gen". It immediately accepted the generator input. TaliaB, Yellow Measure and PsyWulf 3 Quote Link to comment Share on other sites More sharing options...
Yellow Measure Posted March 1, 2023 Share Posted March 1, 2023 7 hours ago, deonholt said: Thanks. I managed to find a setting where I could change the input to "gen". It immediately accepted the generator input. Great! Maybe take a pic next time, to help someone else out with the same problem? Quote Link to comment Share on other sites More sharing options...
PsyWulf Posted March 1, 2023 Share Posted March 1, 2023 21 hours ago, deonholt said: Thanks. I managed to find a setting where I could change the input to "gen". It immediately accepted the generator input. Great,not many inverters do! Quote Link to comment Share on other sites More sharing options...
