Hi all
I have a combiner box with one string the string in connected to 4 x 450watts solar panel.series and parallel as shown below
I am getting power coming out of the solar panel enough to run the system
The combiner box has a  12amp fuse
When I put my multimeter below the fuse I get a reading of 91 volts when I test above the fuse I get 0.29 volts
Can someone help me on how to calculate what fuse size I need as I feel the fuses are blowing but again I am not to sure on how to test them
I am now getting power from the solar panels to the inverter and the batteries are now charging  but the inverter is not should the 230 output I have 0 volts going to the main fuse box.
My system is 100% off grind
The system has 3 x US2000 lithium batteries
The inverter has warning mode 04 which meqns low battery I will waiting until I have 3 green light on the batteries to see if that is the problem at the moment it is on 2green lights but one is flashing so it is charging
