Posted March 11, 20232 yr Good day We have installed the Mecer Sol-AX-5M4 5kva inverter and put in a Rentech 5kva lithuim battery but the battery do not whant to communicate with the inverter. Battery has the following in puts RS485 and Can Inverter has Com and BMS We have put in the cable and the in verter just put out a error 61. In meantime we have put the battery settings on User for know. Does this effect anything. New to the game and what everything to run well. I know i have lots to learn but if any one can assist it will be great. Kind Regards Ingè
March 11, 20232 yr User settings will be fine, there are recommended voltages for 15s and 16s batteries elswhere on the forum You need to check if you have the correct cable with the correct pinouts
