Hi,
Does anybody have experience with Esener lithium iron batteries? It is supplied by Es Energy in Midrand.
https://www.esener.co.za/esener512-100ah.html
Product Description
The ESENER 51.2V 100Ah is a high quality lithium-ion phosphate battery with a lifecycle of more than 6000 at 80% DOD, and can be used for 10-15 years. The battery offers a low internal resistance with excellent continuous high current discharge performance.
Details
  • Advanced BMS with current limiting factor
  • CAN Bus, fully integrates and communicates with leading inverter brands (Growatt, SOLAX, LUXPower, DEYE, MUST, Voltronic, Victron, SMA, etc.)
  • Excellent high temperature performance
  • High Cycle Life and Service Life
  • 1C High Performance Lithium Battery
  • High Energy Density and Conversion Efficiency
  • Complete with integrated Battery Management System
  • Compartible with most inverters and chargers
  • Low self-discharge
  • Easy wall mount or shelf rack installation
  • Heavy duty side handles for easy handling and mounting to the wall
  • Built in protection for over-charge, over-discharge & over-temperature
Specifications
  • Model: ES-5.12KWH
  • Rated Capacity (5HR): 110Ah
  • Voltage: 51.2V
  • Discharge Cutoff Voltage: 40.0V
  • Equalised Charge Voltage: 58.4V
  • Maximum Continuous Charging Current: 100A
  • Maximum Continuous Discharging Current: 100A
  • C. Rating: 1.0C
  • Weight: Approx. 46kg
  • Display: LCD
  • Parallel: Parallel connection up to 15 packs with full communications
  • Dimensions (WxDxH): 505mm x 162mm x 543mm
  • Ports: 1x CAN Bus, 1x RS-485 Battery Link ports, 2x Parallel Instruction Ports
  • Cells:New Li-Ion Prismatic Cells
  • Design Life: -/+ 15 Years
  • Cycle Life @ 1C: +/-4000 Cycles @ 100% DOD, Above 6000 cycles @ 80% DOD
  • Certification: CE, UN38.3, IEC, MSDS
  • Outer Package Material: White bake lacquer steel case
  • Operating Temperature: Charging: 0 to 50°C, Discharging: -10 to 50°C, Storage: -10 to 50°C
  • Protection: Electronic Circuit Breaker, BMS Voltage Protection, Current Limiting
I'm also curious, value for money appears to be really good.
I'm particularly interested in the 5kwh battery.
Anyone else here with one (or more)? How long yiu had it for and how have things been so far?
For my folks, I have ordered the 24v 3kw inverter and 1-off battery. to be a standalone backup unit (not wired in the DB).
Hoping to receive by the weekend but the holiday may delay (inclusive of a mini DB with surge arrestor etc)
I will report back once received and confirmed working.
Any feedback on that inverter Garthox?
I got two installed on Friday. So far so good. Little confused however, the manual and website specs states rated capacity as 110Ah but specs sticker on the battery says rated capacity is 100Ah. But the Deye immediately started communicating with batteries.
On 2023/06/03 at 9:34 AM, Henkus said:
Anyone with an Esener ES 5.12 KWH connected to a LuxpowerTek SNA5000 inverter? What battery setting are you using?
I have the same setup,I used setting 2 and works 100%
I installed quite a few Luxpower SNA 5000 with Shoto, Pylon and Hubble all setting 2 works fine. Setting 2 should be fine for Esener.
Edit: Almost forgot also used Revov R100  battery setting 2.
Edited by TaliaB
2 Essential questions battery system manufacturers should be able to answer to consumers is :
1 : Who manufacture the cells used inside the battery ?
2: Who manufacture the BMS used to protect the cells inside the battery ?
If they don't want to answer these 2 essential questions, then run away !
( Long term testing done in Australia has shown that most battery system failures are due to BMS faults or failures ...)
On 2023/04/24 at 7:12 PM, Clint said:
I installed  a 24V 100ah 2 days ago and seems to be working well
I will let you know how it works
Customer is very happy
I want to purchase one as well. I noticed they don't have a rj45 connector. Does that affect the operation?
I want to purchase one as well. I noticed it doesn't have an Rj45 connector. Will this affect operation?
I am running an Esener Inverter on two Esener 5.12kwh batteries - no issues the last year +
ES-5248 PRO+ Inverter and 2x ES-5.12KWH batteries
Getting a second Inverter and another battery as we speak - because it over performs my expectations in terms of charging and I am increasing my system capacity.
There is a Chinese guy (Kevin) from Esener in South Africa that does support on settings and cabling, etc, works great on text translations (no voice comms)
For small installs, I would definitely suggest the Esener brand - the battery and the Inverter speak perfectly to each other.
