1 hour ago, Treschen said:
Simple and very capable system:
1. Growatt 5kw ES Inverter
2. Pylontech UP5000 with wall mount bracket
End Result: A very happy Customer
Great 👌 my son in law has same except an MK3 Axpert instead of your Growatt.
I was a bit tong in cheek initially because UP5000 is 0.5C only, but its very forgiving with higher loads for quite a number of seconds.
As long as you dont go above 4kw for a sustained period.
Its a good battery. ( @FixAMess did you hear that! ☺️
Edited by BritishRacingGreen
Its a good battery.
@Treschen its also no worry because the Pylon BMS looks after itself, and will cutoff automatically when discharge currents are too high for its own liking.
Yeah i have seen happen, very solid battery though have a few customers who are happy with Pylontechs. BMS is critical with these batts.
I'm investigating importing 5/10 kWh batteries. Price should be compareable with most of what's available in the SA market. Reliable supplier, good quality (?? - always an issue). Usual stuff, 1C discharge, 0.5C charge , 90% DoD giving 6000+ cycles. What is interesting is the 1C/0,5C discharge/charge rating. Which other batteries stipulate this?
Edited by FixAMess
spelling
