Posted February 14, 20187 yr I need an inverter repaired.Where do I send an out of warranty unit to for repair in South Africa?
February 14, 20187 yr 43 minutes ago, flamegrilled said: I need an inverter repaired.Where do I send an out of warranty unit to for repair in South Africa? @Weasel, you guys do this or know someone? These inverters have a couple of common failure points that are now so well known that I'm sure it's probably no biggie for a sufficiently qualified repairer.
February 15, 20187 yr Hi Same question from my side. Need a reputable repairer in the Gauteng area or someone that can test the units. I have 2 that used to work in parallel mode but when the batteries died seems parallel died as well. Individually powered up I cannot select parallel mode. Thanks in advance
February 15, 20187 yr Oh yes! I think the mypower24/solarmd people have the ability to repair as well.
February 16, 20187 yr Author 1 hour ago, SilverNodashi said: mustek could also repair it. RCT is Mustek is RCT. Yes/No? Am I assuming Mustek JHB then?
February 16, 20187 yr 19 hours ago, Henkt said: Individually powered up I cannot select parallel mode. Did you remember to turn the inverter switch off? That setting won't even appear if the power switch is on. It's easy to forget after a long time not having to use it.
February 16, 20187 yr 5 hours ago, flamegrilled said: RCT is Mustek is RCT. Yes/No? Am I assuming Mustek JHB then? Yes. Yes.
February 17, 20187 yr On 16/02/2018 at 12:54 PM, Coulomb said: Did you remember to turn the inverter switch off? That setting won't even appear if the power switch is on. It's easy to forget after a long time not having to use it. Feeling very embaressed Thanks Coulomb - sorted Much appreciate the assistance
