Home Assistant Sunsynk Power Flow Card and Dashboard
Sharing this here in its own thread.
This is my effort to replicate the Sunsynk power flow screen as a custom Home Assistant card as well as some Dashboard ideas I've been using. Improvements and suggestions welcome.
Features
  • Option to switch between two card styles: lite or full.
  • Animated power flow based on positive/negative/zero sensor values with configurable dynamic speed. (Supports inverted battery, AUX and grid power).
  • Dynamic battery image based on SOC (empty->low->medium->high).
  • Grid connected status.
  • Inverter status (standby, normal, self-test, alarm, fault).
  • Configurable battery size and shutdown SOC to calculate and display remaining battery runtime based on current battery usage and system time slot setting i.e. SOC, Grid Charge. Can be toggled off.
  • Daily Totals that can be toggled on or off.
  • Hide all solar data if not installed or specify number of mppts in use. Set custom MPPT labels.
  • “Use Timer” setting and “Energy Pattern” setting (Priority Load or Priority Battery) shown as dynamic icons with ability to hide if not required. If setup as switches can be toggled by clicking on the card
  • Panel mode for bigger card
  • AUX and Non-essential can be hidden from the full card or assigned configurable labels
  • Customisable - Change colours and images
  • Most entities can be clicked to show more-info dialog
  • Optional data points include self sufficiency and ratio percentages, battery temperature, AC and DC temperature
  • Display up to two non-essential, essential and AUX loads
  • Display energy cost per kWh and solar sell status
 You can find the latest version and details here
Documentation
Refer to https://slipx06.github.io/sunsynk-power-flow-card/index.html
Screenshots
*Compact Version*
*Lite Version*
*Full Version*
I've also shared my Home Assistant Dashboard that works well for me. You can find the latest version and details here https://github.com/slipx06/Sunsynk-Home-Assistant-Dash
Edited by slipx
  • Replies 592
  • Views 132.2k
  • thank you @slipx, I've been using the power flow card for a while now but didn't know about the animations. now thanks your examples I've implemented the animations. I use a generator on my AUX port
  • I've made  a small update to the Dashboard. The load shedding card shows remaining time based on battery SOC and battery power. You will need to create some template sensors as discussed here and prov
  • Here's a slight contribution to the goodness on this thread which lives on my main HA screen: type: custom:bar-card entities: - entity: sensor.load_shedding_area_eskde_4_sandownext10cityofj
12 hours ago, cc120689 said:
Hello, you have made a fantastic card, I have done something similar but using the flowchart plugin in grafana, the problem is that it is very slow to display.  How could I do to convert my flow chart into a card like yours?  thank you
Thanks. The card provides you with a framework to display any svg image and text elements. You would need to save your graphics as an svg image and then position your text placeholders. The bindings reference the text element and the sensor data you want to display.
For example this is the placeholder for battery soc referenced by a text id. The x and y position and some styling applied. There is a default value of 0 when no sensor data is available
<text id="battery_soc_184" x="9%" y="87.5%" class="st2 st4 st8">0</text>
The code below maps the sensor value you want displayed to the text element.
  - bind: return hass.states["sensor.battery_soc"].state + ' %'
    selector: '#battery_soc_184'
    type: html
    type: html
But is there a graphic helper to place my elements and then pass it to text for the card?  Or do I have to replace your images with mine one by one and move the text boxes by changing the coordinates in the text?
Thanks again !
You can use Draw.io (https://app.diagrams.net/) to create your image layout (graphics, text boxes etc) and then export to svg. I've included my draw.io files in the repo as examples. The SVG can be opened in a text editor and you can add your text elements. To visualize open the SVG in a browser. You can then continue to edit in the text editor save and refresh the browser window to see updates.
ok, I had seen how to create the link to replace an image of yours with one of mine, such as the one from sunsynk, I had changed it to the one from turbo energy, but I don't see the way to export all the text boxes with their position etc. I'll take a closer look at it, thanks!
Hi, I'm finally changing the images one by one and changing sizes and position on the map, but I have a question, how can I make the text appear above an inserted image? Let the image remain in the background and the numbers above
SVG elements are painted in order. Just place it after the image in the svg file and it will be drawn on top. e.g  the text will be placed on top of the green circle
<circle cx="50%" cy="50%" r="20" fill="green"/>
<text x="50%" y="50%" class="st1 st3 st8">Hello</text>
Edited by slipx
Have a look at this code
<animateMotion dur="9s" repeatCount="indefinite" keyPoints="0;1" keyTimes="0;1" calcMode="linear">
      <mpath xlink:href="#pv1-line"/>
    </animateMotion>
You could probably create another circle and reference the same path and change either "dur" attribute to a different time or you can change the "keyPoints" attribute. 0 represents the start of the path and 1 the end. So you could have an animation that goes halfway i.e. keyPoints="0;0.5" and for the second dot starting halfway keyPoints="0.5;1"
Hello, I follow the instructions and it gives me an error when inserting the card: "Custom element doesn't exist: sunsynk-card.
What am I doing wrong?
56 minutes ago, RET said:
As I said, I followed the instructions
Steps 1 -> 3
This will let the system use that resource
  1. Create a new directory under www/community/ and name it sunsynk-card. If you don't have HACS installed you can create directory directly under www and reference in step 3 below.
  2. Copy the sunsynkcard.js into the directory
  3. Add the resource to your Dashboard
Afterwards it should show :
Edited by Gary Waterworth
2 hours ago, Gary Waterworth said:
Steps 1 -> 3
Thanks for the help but I can't get it. It's very weird
Edited by RET
To add the resource You must click on the 3 points at the top to the right of home assistant, edit control panel and then again those 3 points and manage resources, you will get a window where you can add the sunsynkcard.js resource
Finally I got it. I don't really know what was wrong with me. Thank you so much
I have been looking at the "animated_card_configuration_full.txt" file and there is a sensor called "sensor.sunsynk_essential_load", this sensor I don't know where it comes from, it is not in the "ESPHome.yaml" file. Can somebody help me? Thank you
sensor:
 - platform: template
   sensors:
     sunsynk_totalsolar:
       friendly_name: "Total Solar Generation"
       value_template: "{{ (states('sensor.pv1_power') | float(0) + states('sensor.pv2_power') | float(0)) | round(0) }}"
       unit_of_measurement: 'W'
     sunsynk_solar_load:
       friendly_name: "Solar Load"
       value_template: "{{ (states('sensor.daily_pv_power_kwh') | float(0) - states('sensor.battery_charge_day') | float(0)) |round(1) }}"
       unit_of_measurement: 'kWh'
       device_class: energy
     sunsynk_essential_load:
       friendly_name: "Essential Load"
       value_template: "{{ (states('sensor.inverter_output_power') |float(0)  - (states('sensor.aux_output_power') |float(0) - states('sensor.grid_inverter_load') |float(0) )) | round(0)}}"
       device_class: power
There are a couple of template sensors you need to create, either in HA or your ESPHome config. If you don't have any AUX or Non-Essential loads you can substitute sensor.sunsynk_essential_load with modbus register # 178 Load Power
Edited by slipx
sensor:
   sensors:
     sunsynk_totalsolar:
     sunsynk_solar_load:
       device_class: power
Thank you very much for sharing your work
