Posted March 22, 20232 yr Hi hi. I have 3 x synerji 5.6 connected in 3phase system. Setting 28 is on 3p3. If i edit 1 the others edit too. However. I am getting no output. Inverters are on but no load output. 3phase back up system on rural farm for pumps.
March 24, 20232 yr On 2023/03/23 at 12:25 AM, Lawd_Kallie said: Setting 28 is on 3p3. If they are like Axperts (they might even BE Axperts these days), you need one of them on 3P1, one on 3P2, and one on 3P3. Quote If i edit 1 the others edit too. Do you mean that if you change one to 3P3, the others also change to 3P3? That's weird if so. I note that on Axperts at least, you can't changes setting 28 (AC output mode) when the power switch is on (there must be no output when changing output mode).
