Chetty Posted March 23, 2023 Share Posted March 23, 2023 I have a DEYE 5kW inverter that is connected to 2 x X100 Hubble batteries. I have an ethernet cable connected between the inverter and the master battery and another one between the master and slave battery. Can this setup actually communicate between the battery BMS and the inverter or must the setting be for voltage based settings? I am reading mixed documents that seem to state that there is no CAN or 485 communication possible. Quote Link to comment Share on other sites More sharing options...
HendrikBigChief Posted June 6, 2023 Share Posted June 6, 2023 You should be able to get comms up with RS485, just set your batteries to master pack and pack1 as the manual shows. One tip with Hubble batteries is to make sure they fully charge at least once a day. That keeps the voltage from drifting over time. Good luck. Quote Link to comment Share on other sites More sharing options...
Chetty Posted February 24 Author Share Posted February 24 What are pinouts for the RS485 cable that I would require for the communication between the inverter and the X100 batteries? Quote Link to comment Share on other sites More sharing options...
CobusK Posted February 24 Share Posted February 24 5 hours ago, Chetty said: What are pinouts for the RS485 cable that I would require for the communication between the inverter and the X100 batteries On the inverter side : Quote Link to comment Share on other sites More sharing options...
