Kodak Inverter not charging and no output when running off battery
Need some assistance please. Not sure if I have a faulty inverter or incorrect settings.
My setup:
1x Kodak Off Grid 5.48 Inverter
1x Pylontech US3000 Lithium Battery
Since about a week ago, my inverter failed to kick in during loadshedding. When drawing power from the mains, the inverter shows the battery is charging, and input and output is the same.
The problem is when loadshedding occurs (off mains), inverter displays error 04, with the battery icon flashing. Input = 0v and Output = 230v
Had the battery tested, and thats working fine
Is it error code F04 or warning code 04?
With output voltage showing 230 V and no utility, you should be able to run loads. Oh, unless it's during the day, when perhaps solar power could be providing the 230 V output. But even then, you should be able to run small loads.
I'm not understanding "no output" if the output voltage is 230 V.
  • 4 months later...
Hi, I have a kodak 6.2kw inverter with four pylon batteries. The inverter worked well for a year but now the inverter shuts off the output during the day. It happens randomly and everything on the inverter shows normal.
What is the battery voltage shown on the inverter when that happens?
Is the battery basically full by then?
Does the battery show any warnings or errors?
