Posted March 26, 20232 yr My battery charge voltage point is set to: 56 volts full charge 48 volts back to utility My question please if any one can assist 1. What must the Bulk charging voltage setting be - 56.4v at the moment. Same with Floating charge - 54.0v at the moment. Need to know if correct or what should it be? 2.Low DC cut off set to 45v, is this correct?
March 26, 20232 yr I have the Raystech 5100s. Same battery, different brand. Voltages are below. Cutoff is 49v
