Posted February 22, 20187 yr Hi Guys New to the forum, have someone on this forum perhaps tested the Axpert vs Growatt inverter and which one do you think is better. I only have installed Axperts so far, but have a friend that recommends the Growatt for better performance. Looking forward to your opinions
February 22, 20187 yr I have no idea what they are like but I think the topic has come up here before (use the search function). Also, looking at the pictures seems to suggest the Growatt is made to a higher standard, eg IP65 casing etc. It also seems it is well known over in Ausie-land, here, and here. And also in India. And it has a slightly better warranty by the looks of it. Personally, if you forced me to pick one or the other (cause I'd prefer neither... :-P), I'd pick the Axpert simply because it is a more well-known poison with some support in this country, for some value of support.
April 6, 20214 yr Hi, I am trying to find out which "language" / Software Growatt 5000 ES uses. I used to have Axperts, monitored by ICC software (https://centurionsolar.co.za). This doesn't talk to the Growatt. I presume it is different kind of software. ICC will write this into their software. All I need is to find out what language the Growatt is speaking. Thanks
