Good day.
I installed a solar system consisting of 2 x 12kw Deye inverters in parallel. System on its own working well. I need to connect a 20kw Bundu generator to the system. After setting up the inverters for the generator it don't show the generator icon on the home screen. If I increase the starting % of the batteries, the generator starts but the inverter does not "accept" the charge voltage. Testing at the inconnection it gives 380 volt.
When using the ti.e slots to start the generator, the same scenario. It the also does not switch off the generator after the time collapsed.
Hope you guys can help!
