Posted March 29, 20231 yr Hi Guys Can anybody guide me to comms between Deye 8kW (SUN-8K-SG01LP1-EU) and 2x Averge LfeLi-48100S batteries please? Cables required, DIP switch settings and good software to use for system monitoring. Does one manually need to set percentages for cut, restart, etc. Much appreciated guys.
March 29, 20231 yr The Deye comes with a wifi dongle that is integrated with Solarman - the platform is decent for day to day monitoring of what's going on from a PV, Inverter and battery perspective. There IS a delay in getting the data so if you want / need more time-sensitive data then something like Solar Assistant would be your best bet - it IS paid for though The batteries should hopefully come with the required cables, if not the averge website should guide in terms of the pin out you need to use (attached). You will need to setup the percentages for cut, restart etc on the inverter according to your use cases and needs
April 5, 20231 yr Author Good morning All System is working but struggling with comms between batteries and inverter. I have coupled two batteries with straight Ethernet cable between RS485 interconnect ports, set battery dip switches to master=1, slave=2, ran supplied cable (pic attached) between master battery second RS485 port to inverter, connected CAN cable from inverter (2-wire) to master battery but still fail to read battery status from inverter. Any guidance would be greatly appreciated, thank you.
