Posted March 31, 20232 yr Good Day This week I have installed my Deye inverter with two Hubble batteries. PV will be installed next week. However, when there is load shedding the inverter kicks-in and house operates as expected from DC system. However, after load shedding the batteries does not charge, reducing SOC from 100%, loadshedding, 84%, load shedding, 79%, etc. Current SOC is 47% The attached images are from the Deye inverter screen setting, that shows the following: 01) - Latest Deye software update: Ver 0-6022-1724 02) - Li-BMS Settings 03) - System Grid Charge Settings (time of use tick, time slot grid charge ticked, etc.) 04) - SOC Graph after each load shedding I have restarted the system a few times, then grid charge will be for 1% and nothing thereafter. Is there some obvious aspect / setting I am missing? Thanks in advance for your assistance, as I have tries various videos, online searches until I found this forum.
March 31, 20232 yr This is a known issue in the latest firmware. Ask your installer to downgrade until a fix is released.
March 31, 20232 yr Author Thanks Justin, reverted to the previous firmware version and batteries is charging from AC 😀👍
April 3, 20232 yr Hi M using Deye inverter 8kva which was installed 2 days ago now it has stopped charging bettries from the panels it only charge with grid what should I check please assist
May 26, 20231 yr I have the same inverter with the exactly the same problem. Solar charging works beautifully, but as soon as grid charge needs to kick in, shows off grid on main display. Does make a disturbing crank sound from time to time, where the “off grid” display disappears momentarily, then goes back, and doesn’t charge from grid.
August 22, 2024Aug 22 I have a Deye 6 kW working for auto-consumption (Setup LD Load & Zero Export) which is having the same issue. From the solar panels is charging without any problem but is not charging from the grid having the time of use checked.
