Deye inverter and volta battery setup
moe754
8 hours ago, moe754 said:
Hi. Have a deye 5kw inverter and volta battery with 6 solar panels. Noticed that the battery never charges to 100%.. always 99% .. is there a setting that Is not right or is that the way it should be?
Pretty normal, once the battery reaches full charge voltage the voltage will slowly drop as the cells balance until they reach resting voltage. This often results in a very small reduction  in the capacity as the volts reduce which in turn impacts SOC.
Assuming you have BMS and inverter communication in place.
