Does anyone use Sunrover batteries ?
I am struggling to find the manual for this 100Ah battery and the dipswitches configuration... Trying to connect it via BMS to a Deye hybrid.
Hi,
I have only one battery so I set the dip switches all to off.
I connect both CAN ports, but it doesn't work. Could you please give me your battery settings of the inverter?
Best regards
Hi,
the battery is on. The voltage is so small because the DC breaker was off. I did the reset and switch the DC breaker on but I think I have no BMS connection. Could you confirm my configuration?
THANKS
If voltage is OK now , connect the BMS cable and let it search for the battery for at least 10 minutes. If no luck then try to pull network cable out and in again and wait again a few minutes, It will take a bit of time for the Auto BMS to catch on.
Frustrating..:-( I did it several times without success.. Is the Cfg Hw and Sw the same at your setup? Do you have several accus?
Edited by sunbiker
