Posted March 5, 20187 yr Anyone know a good local source for 12v DC LCD battery voltage meters? They should be powered by the battery itself. Also I'm looking for a LCD voltmeter that can measure in the range of 40-60v DC
March 5, 20187 yr https://www.bidorbuy.co.za/item/325759559/Voltmeter_Digital_Red_0_30V_DC_IN_STOCK.html Self voltage measurement = 4.5-30 VDC Seperatel supply measurement = 0-30 VDC The same supplier has other 0-100 VDC (and 0-50ADC) that will require isolated supply which can be accomplished by using small cheap(ish) DC-DC converter.
March 5, 20187 yr 14 minutes ago, pilotfish said: I have used the dude before and he is reliable. I've used him more than once too. Very good seller.
March 5, 20187 yr I have recently purchase 4 of these meters. 0 to 100V DC https://www.takealot.com/lumeno-volt-amp-meter-black/PLID41395303
March 6, 20187 yr 7 hours ago, DeepBass9 said: Does that amp meter use a shunt or direct through the unit? From the diagram it connects directly through the unit. I have not connected them up yet, hopefully I will get a chance this weekend.
