Hi there,
Really hoping to get some experienced advice from someone here as im quite useless with this stuff, so here goes!
Im looking into buying a plug & play power station for my office. I'm currently running a Mecer 2.5kVa with 2 lead acid batteries and the batteries have started giving in.
So its time now to upgrade to a lithium battery system.
Here are the 2 options I'm thinking of:
https://powerprovider.co.za/product/2-5kva-2-56kwh-lithium-compact-power-station-2500w/
OR
https://powerprovider.co.za/product/3kva-2-75kwh-lithium-compact-power-station-3000w/
My question is first - do you know if these particular inverters are noisy? Or at least noisier than your average inverter, my current one makes a fan noise when recharging which is certainly audible but not annoyingly so. And a friend of mine said the RCT's are noisey but not sure i can rely on his advice so just wondering if I could expect the same level of fan noise or if it will be worse.
My second question is: My current power load is hitting 20% and hardly ever goes over that amount with all computer equipment and lamps running.
Do you think there will be much of a difference between these 2 options in terms of how long the battery will last. The first option has  2X Hubble S-100 A 1.28kWh LiFePO4 and the other has 1 Hubble AM-4 Lithium-Ion Battery 25V 100Ah – 2.75kWh – 1C Battery
So just wondering which option will be best for the longer lasting battery.
Look forward to hearing your advice.
