Good day , I have two by 8 PV Strings. On PV1 I get 50 % less output voltage compared to PV 2. When I change PV1 string with PV2 input on the inverter  ,I get the correct input. And the PV2 string into the PV 1 input on the inverter then drops to 50% compared to the input at PV 2.
Any ideas on what is causing this. Is the PV1 input on the inverter having a problem?Any ideas would be appreciated.
10 hours ago, Phil1 said:
Is the PV1 input on the inverter having a problem? Any ideas would be appreciated.
It sounds like it.
Maybe a loose connection inside the inverter? Does the PV1 input seem to get hot? Though it might be further inside the inverter.
On 2023/04/14 at 4:15 PM, Coulomb said:
It sounds like it.
The inverter was now replaced with new and the new unit is working perfectly. Issue on the PV1 input on the inverter.
