MUST
Taher Sylla
9 hours ago, Taher Sylla said:
I've got MUST inverter installed to a customer, but it is not charging from utility ( the picture below ) , there are no errors or faults, the inverter detects the battery but only charges from solar, how can we fix this ?
You need to change in program 10 which is  the charging source from OSO to one of the 2 othere charging source as OSO is solar only
Everything was fine, all the settings were true and no mistake, so I didn't know what is the problem, so I tries facgory reset ( press menu button 6 seconds ) and enter the same parameters and worked perfectly fine
