Setting Sunsynk charge level
j14jan65
1 minute ago, j14jan65 said:
Hi all.
Does anyone know if it is possible to limit the battery charge to 80% max?
Inverter 5kva
Battery Sun-Batt-5.32
The sunsynk inverter and sunsynk battery combo should/must be connected to use the comms, they will then talk to each other to use the 100% correct settings.
If you want to manually set then you may need to check on your warranty conditions as you may end up voiding it.
Hi, they're connected and working fine. I just wanted to know if there is any way I can set the charge to stop at 80%.
Only when you are doing grid charges , if there is PV available it will always charge to 100%.
