Growatt SPF5000TL-HVM with Shoto sda10-48100
Tsa
Got this working for someone
If i remember correctly
It was just a question of getting the correct cable made up
ie find the pinout of the growatt  and the pin-out of the pylontech
Edit based on reply you can see i lost the plot , but assume the same applies to shoto so data that follows has been changed to match what i find on shoto
If they speak the same language naturally it will work otherwise not
i would remove all battery cables (to slaves) until you have a connection between inverter and master battery
and then later do slave setup
set all dip switches off (bottom) if having multiple batteries 000000 is master  no idea how slaves need to be set
just that the dip switches respresent 6 bit dial switch
When making up cables mark inverter side and battery side naturally
there is 2 forms of communication RS485 and CAN
the shoto has 3 ports that deal with coms
4 (on layout img) does CAN
3 does rs485 the right one is the one used to connect to slave batteries (would connect it to the left side on next slave and use the right one to connect to next slave again ie like cascade image attached at the bottom
if coms to inverter has to be rs485 then use the left one to connect to inverter
or 4 CAN if that is what inverter uses
use a cut cable and join wires from appropriate pins and test until you have a working cable
on rs485
The shoto uses pin 1/2 for data rs485 coms and 8 for ground and it seems the growatt uses 1/2 too (not sure on ground)
so try a straight connection from 1-1 and 2-2
If that doesn't work try crossing 1-2 and 2-1
and on rs232/CAN it uses pin 3/4/5
5 for ground and 3/4 data
some have a 6pin rj11 and some use a 8pin rj45 connector seems they all use 3/4/5 (salt, just what the 2 manuals i have say)
And growatt uses 3/4/5 too but it has ground on 5
So connect pin3 on battery side  to pin5 on inverter side for ground
and for data
 4 on battery side to 3 on inverter side
And 5 battery side on 4 inverter side
if no success swop the two data lines around ie connect  4-4 and 5-3
There is a few different shotos so not sure if all the same pin-outs
I would make a cable try all the different Li options if no success then alter the cable run through all the options again , too see if one of them matches the shoto
if through all cable variation and settings with no success  , i would just run it in dumb mode
Edited by Leondavibe
cleaned up the post to make more sense(hope i succeeded)
