shovelhead Posted April 29, 2023 Share Posted April 29, 2023 I haven't changed my Sunsynk time recently (not in months that I can remember) and noticed that it appears to have gained an hour - I set it back an hour, and a few minutes later it advances another hour. I noticed that it is set to "sync" so going to try and untick it now, but wondering why this has changed all of a sudden. Has anyone else experienced this ? Quote Link to comment Share on other sites More sharing options...
mzezman Posted April 29, 2023 Share Posted April 29, 2023 Could be syncing with a time server that's moved an hour ahead? Try untick sync and see if it keeps the time over the next 24hrs zsde 1 Quote Link to comment Share on other sites More sharing options...
zsde Posted April 29, 2023 Share Posted April 29, 2023 It does sound like a daylight savings provisioning at their sync server level. SA does not have daylight savings which begs the question whether the inverters are registered by country and serial number and that it may somehow linked to a country that does have daylight saving. Or the sync server may have SA in error as a daylight saving region? Scorp007 and mzezman 2 Quote Link to comment Share on other sites More sharing options...
shovelhead Posted April 29, 2023 Author Share Posted April 29, 2023 18 minutes ago, zsde said: It does sound like a daylight savings provisioning at their sync server level. SA does not have daylight savings which begs the question whether the inverters are registered by country and serial number and that it may somehow linked to a country that does have daylight saving. Or the sync server may have SA in error as a daylight saving region? This was my thought also. BTW unticking the sync option has solved the problem mzezman and zsde 2 Quote Link to comment Share on other sites More sharing options...
mzezman Posted April 29, 2023 Share Posted April 29, 2023 They should give the option to specify a time server in the apps zsde 1 Quote Link to comment Share on other sites More sharing options...
sgs Posted April 29, 2023 Share Posted April 29, 2023 My Deye has done the same. Drove me nuts before I figured out what was happening. I suspect it is related to the timezone setting in Solarman. Mine is set to GMT+2 Cairo, and Cairo does have DST, which kicked in last Friday. There is no way to change this though as my installer controls the plant in Solarman. Does anyone know if Solarman has a timezone for South Africa, though? If so I need to shout at my installer to fix it or to give me control over the plant in Solarman so that I can manage it myself. Quote Link to comment Share on other sites More sharing options...
mzezman Posted April 29, 2023 Share Posted April 29, 2023 Solarman does indeed have a Harare/Pretoria timezone Quote Link to comment Share on other sites More sharing options...
shovelhead Posted April 30, 2023 Author Share Posted April 30, 2023 12 hours ago, sgs said: My Deye has done the same. Drove me nuts before I figured out what was happening. I suspect it is related to the timezone setting in Solarman. Mine is set to GMT+2 Cairo, and Cairo does have DST, which kicked in last Friday. There is no way to change this though as my installer controls the plant in Solarman. Does anyone know if Solarman has a timezone for South Africa, though? If so I need to shout at my installer to fix it or to give me control over the plant in Solarman so that I can manage it myself. I thought this would be the solution, and changed mine from Cairo to Harare, Pretoria. Unfortunately it still adds an hour within a few minutes. Quote Link to comment Share on other sites More sharing options...
Yellow Measure Posted April 30, 2023 Share Posted April 30, 2023 59 minutes ago, shovelhead said: I thought this would be the solution, and changed mine from Cairo to Harare, Pretoria. Unfortunately it still adds an hour within a few minutes. The time server that it syncs with belongs to Sunsynk, not Solarman. I had a similar issue where it placed mine in a GMT timezone, so I asked support to intervene on the Segen Sunsynk group. They never gave me any feedback (seldom do), but at least it was fixed. There is a lot of value in having a time sync, just a PITA when it goes wrong. It would be nice to be able to select timezones on the Sunsynk inverter, as well as a user-defined local one, or a proper stratum-2 time server from http://www.time.org.za/ Quote Link to comment Share on other sites More sharing options...
gthorn Posted May 9, 2023 Share Posted May 9, 2023 I'm having the same problem. I noticed it yesterday for the first time. I fixed the time but I just noticed that it jumped an hour ahead again. I have now turned off "Time Syncs" to see what happens. I have a Deye 8kw inverter and it was connected to SolarMan when installed last October. I have a friend who installed the same setup a week ago and he does not have the problem (so far). His inverter is not connected to Solarman, so my guess is that Solarman has something to do with it. Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted May 9, 2023 Share Posted May 9, 2023 (edited) 8 minutes ago, gthorn said: I'm having the same problem. I noticed it yesterday for the first time. I fixed the time but I just noticed that it jumped an hour ahead again. I have now turned off "Time Syncs" to see what happens. I have a Deye 8kw inverter and it was connected to SolarMan when installed last October. I have a friend who installed the same setup a week ago and he does not have the problem (so far). His inverter is not connected to Solarman, so my guess is that Solarman has something to do with it. Just use synch with the correct timezone. Problem solved. Or solved on some inverters. Edited May 9, 2023 by Scorp007 Quote Link to comment Share on other sites More sharing options...
mzezman Posted May 9, 2023 Share Posted May 9, 2023 Make sure to change the timezone on the webpage of solarman to Harare/Pretoria Quote Link to comment Share on other sites More sharing options...
OffGrid Posted May 9, 2023 Share Posted May 9, 2023 On 2023/04/29 at 3:06 PM, shovelhead said: This was my thought also. BTW unticking the sync option has solved the problem Thank you sooo much for this. Unticked the sync option, changed the time back to correct time and it worked!! Quote Link to comment Share on other sites More sharing options...
ZA Moose Posted September 7, 2023 Share Posted September 7, 2023 Same issue on Deye 12Kw 3phase. Select correct time zone and disable sync on solarman Quote Link to comment Share on other sites More sharing options...
