Posted April 9, 20187 yr I was testing my inverter after a new install of a backup mppt charge controller and wanted to put it through its' paces. What I didn't count on is cloud edging that day. I am hoping the inverter, itself, wasn't just going crazy. I'm trying to figure out whether this is normal during cloud edging. Everything seemed to run fine. Just looking to see if I am correct in assuming that this is the norm. Thanks.
April 9, 20187 yr Not sure what to look for and all that noise is too much to live through :-) (Are those inverters really that noisy as in the opening segment!?) Anyway, yes, cloud edge effect can be dramatic. I've seen my +-1.8Kwp array push 2.3KW at the peak. That's almost 30% over.
May 29, 20186 yr Author Yeah...I should have toned down the noise. That's not actually the inverter. That was the drill, a grinder and another specialized tool running with a few other little loads as well. They were all running at the same time. I keep it raw as some people think editing removes the "seeing is believing" aspect. Yeah...sorry about that. Thanks for the constructive criticism though.
