ZioVas Posted May 14, 2023 Share Posted May 14, 2023 Hello Power Forum, I am facing a communication problem between Pylontch US3000C and SMA Sunny Island 8.0H_V11. According to manual, we have to use the RJ45 pins as the pic attached. The Sunny Island uses CAN protocol. So, my question is that we should use the left column of the pic, at both battery and inverter slots? And what about Pin7 and Pin8? Do we keep them NULL? Thank you so much in advance for any guidance.. Quote Link to comment Share on other sites More sharing options...
Tinbum Posted May 14, 2023 Share Posted May 14, 2023 (edited) Use 4,5 and 6 on the battery end and look at your SMA instructions for the inverter end. (4,5,2 going from memory) Edited May 14, 2023 by Tinbum Quote Link to comment Share on other sites More sharing options...
ZioVas Posted May 14, 2023 Author Share Posted May 14, 2023 2 hours ago, Tinbum said: Use 4,5 and 6 on the battery end and look at your SMA instructions for the inverter end. (4,5,2 going from memory) 2 hours ago, Tinbum said: Use 4,5 and 6 on the battery end and look at your SMA instructions for the inverter end. (4,5,2 going from memory) Thank you for your response..attached the pic with the pins from the SMA instructions, it's as you remember.. But what is pin 3 (SYNC_H) and pin 6 (SYNC_L)? Should i connect anything more to the corresponding pins at the battery side? Quote Link to comment Share on other sites More sharing options...
Tinbum Posted May 14, 2023 Share Posted May 14, 2023 You only need the CAN. It is all in the instructions. SYNC is for inter inverter comms. Quote Link to comment Share on other sites More sharing options...
