To many plug sockets on my PLUGS CB for my inverter
Good Morning,
We run Self Catering accommodation in the Western Cape… We are getting Grid Tie inverters with Lithium batteries installed, but I am for seeing a problem, the LIGHTS and PLUGS circuits will be wired to the inverter and batteries…
These units are small so there is only 1 PLUG CB in the DB… Now, despite proper explanation and signage in the unit, guests could try to run the electrical kettle and toast a couple of slices of bread… Which will drain batteries in about an hour leaving them in the dark for the 3 hours remaining on our loadshedding schedule…
Any quick and easy solutions to isolate some plug outlets on a plug circuit, yet have them back on when the loadshedding session ends?
Thank you so much!
N
You can open die Db and check if there is more than one circuit connect to the 1 Breaker. If there is 2 circuits split them and only connect the 1 to inverter via a smaller breaker that will trip if any higher amp equipment is connected. The other option is to install a additional plug with a low amp breaker from inverter.
