IM B Posted May 19, 2023 Share Posted May 19, 2023 I have a: -1x Victron multiplus II 5kva - Cerbo gx -1x Freedom won eTower. The eTower shows up on the cerbo, but when I check the firmware version it shows, |--|. Any ideas why this is the case? I experienced two issues which I'm not sure is actually normal.Can anyone comment on these as well? -The battery is rated at a continuous load of 4.7kW with a max discharge at 5,2kW, however I tested the battery with a load of about 4,3kW and the battery switched off. The battery was at about 98% state of charge. -There was another time when the battery switched off with a load of about 3.4kW at around 70% state of charge. Surely the battery can handle these types of loads. Quote Link to comment Share on other sites More sharing options...
PsyWulf Posted May 19, 2023 Share Posted May 19, 2023 Just a note: Load at the Load != Load at the battery,there is a conversion loss so your 4.3kW load could well have pulled something closer to 4.7kW at the battery The 3.4 is a bit more anomalous Quote Link to comment Share on other sites More sharing options...
