Crankshaft Posted May 19, 2023 Share Posted May 19, 2023 I'm wondering why a solar panel manufacturer has panel ratings so close. Checking out the Canadian HiKu mono panels. There is a 375w and 380w model. Size and weight identical, small price difference. Why would a manufacturer make panels that are so similar. I wonder why anyone would choose one over the over. My guess is that when the cells are selected , the better-performing cells go on the 380w panel. Could also be an older and a newer model. Quote Link to comment Share on other sites More sharing options...
Eurard Posted May 19, 2023 Share Posted May 19, 2023 4 minutes ago, Crankshaft said: I'm wondering why a solar panel manufacturer has panel ratings so close. Checking out the Canadian HiKu mono panels. There is a 375w and 380w model. Size and weight identical, small price difference. Why would a manufacturer make panels that are so similar. I wonder why anyone would choose one over the over. My guess is that when the cells are selected , the better-performing cells go on the 380w panel. Could also be an older and a newer model. Maybe has to do with Parallel and Serie strings etc, but yeah with you, never could quite understand this, so keen to know the answer as well ... Quote Link to comment Share on other sites More sharing options...
mzezman Posted May 19, 2023 Share Posted May 19, 2023 5 minutes ago, Crankshaft said: I'm wondering why a solar panel manufacturer has panel ratings so close. Checking out the Canadian HiKu mono panels. There is a 375w and 380w model. Size and weight identical, small price difference. Why would a manufacturer make panels that are so similar. I wonder why anyone would choose one over the over. My guess is that when the cells are selected , the better-performing cells go on the 380w panel. Could also be an older and a newer model. you answered your question there similar to how chip manufacturers would have an i3 and i5 from the same silicon wafer but different bins. LLawrence and RocketBoy 2 Quote Link to comment Share on other sites More sharing options...
Crankshaft Posted May 19, 2023 Author Share Posted May 19, 2023 That makes sense. Thank you. Quote Link to comment Share on other sites More sharing options...
