Dougbb Posted June 4, 2023 Share Posted June 4, 2023 Hi, I am trying to build a charger to charge my 12V lead acid batteries. I use these to power lights during load shedding. I bought a XH-M602 module, https://www.robofactory.co.za/charging-modules/519-xh-m602-digital-control-battery-charging-module.html. Has anyone used this and could you give me an example of what charger you use that goes between the above module and the battery? Thank you Quote Link to comment Share on other sites More sharing options...
Scorp007 Posted June 4, 2023 Share Posted June 4, 2023 9 hours ago, Dougbb said: Hi, I am trying to build a charger to charge my 12V lead acid batteries. I use these to power lights during load shedding. I bought a XH-M602 module, https://www.robofactory.co.za/charging-modules/519-xh-m602-digital-control-battery-charging-module.html. Has anyone used this and could you give me an example of what charger you use that goes between the above module and the battery? Thank you You can use any charger as this module is set to disconnect the charger at the custom voltage you key in. It will be good to get an intelligent charger just in case this module fails to prevent a cheap module causing damage to a battery costing 10 times more. I use mine about weekly when I charge a DIY lithium battery Quote Link to comment Share on other sites More sharing options...
Dougbb Posted June 10, 2023 Author Share Posted June 10, 2023 Thanks for the response, I'll add in another one and see how it goes. Quote Link to comment Share on other sites More sharing options...
