Inverter to install in kitchen
Can anyone make a suggestion for a 3Kw or a 5Kw inverter with a 5Kwh battery that would be suitable to install in a small kitchen?
My mum lives in a small flat in a retirement village and does not have a garage etc. so needs tp be indoor.
I love my Sunsynk but it is very noisy when the fans start, and while the Livoltek at the office is very quiet, it’s pretty expensive. Any other ideas or suggestions?
Sunsynk 5kw doesn't have fans
As far as i know the 5 kw Sunsynk do have fans on the inside of the enclosure cooling the heatsink from the bottom comes on around 58c and goes off 65c. You can actually hear them when terminal cover is removed. Not loud but if mounted in your bedroom at night you will hear them if the fans switches on.
Edited by TaliaB
