Deye Inverter 8kw inverter settings
Henkg
Hi,
I just had a Deye 8KW system with 2x5.1 Hubble Lith iron batteries and 14 545/550 W solar panels installed. What is the difference between the Zero export to load and the zero export to CT settings on the inverter?
2 hours ago, Henkg said:
To direct it between essential and non-essential did the installer have to set it up in this way ?
They didn't have to but generally they do that to limit the amount of high energy devices on the inverter. Also, it's not clear if he put any devices on non-essentials.. The inverter has that functionality by default
So my understanding is that:
- If you have Zero export to load ticked it will not back feed any power out through the Grid-Input.
- If you have zero export to CT ticked, it will back feed power up to the CT clamp and as such can power the non-essential loads if possible.
This above is correct.
Personal opinion, I don't think there's an absolute right or wrong way here about what the installer could/should've done.
Just intuitively, the logical default for an installer should be to keep everything on essential loads, nothing wrong with that.
Gut feeling is, diverting power to non-essentials could/should only be done after consulting with the owner and educating him about the options. That would be a nice touch, good service, better than to make assumptions about the client's needs, and better than just leaving him to read the manual.
A lot of the recent installs are wham bam no thank you mam style...
